HP Color LaserJet MFP M274n - bad colors at copies only (scan good colors)
  • spree
    • Jun 2012
    • 211
    [Misc] HP Color LaserJet MFP M274n - bad colors at copies only (scan good colors)
    Hello,
    I have here HP Color LJ Pro MFP M274n:
    - with non genuine cartridges!
    1.) printing is excelent - see scan image attached
    2.) scaning is good - see scan image attached
    3.) but copies are not good - colors are not good - best to see at yellow color - see scan image attached
    What was maked:
    - flashing the newest firmware (
    - reseting the printer to the defaults
    - NAND reset (in 2nd service mode)
    - perform Scan Calibration (in 2nd service mode)
    - perform Super NVRAM initialization
    Still the same problem.
    Where can be the problem (bad scanner assembly - B3Q10-60125 ?) or some electric board?, but scaned image has perfect colors, but copies have not good colors.
  • aAandy
    • Apr 2012
    • 370
    Re: HP Color LaserJet MFP M274n - bad colors at copies only (scan good colors)
    Originally posted by spree
    Hello,
    What was maked:
    [ATTACH=CONFIG]45206[/ATTACH][ATTACH=CONFIG]45207[/ATTACH]
    start by installing genuine carts - the cyan doesn't look like it's quite the right color and i've seen this a few times
