HP 3055 MFP ?
  • KHAN
    • Aug 2006
    • 261
    HP 3055 MFP ?
    Hi friends my MFP 3055 works fine when i use it as a printer,copier and fax , but when i use the scanner it show error CAN NOT CONNECT from both sides , from pc to scanner or scanner to PC,
    Please any suggestions.
  • prntrfxr
    • 1627
    HP 3055 MFP ?
    Not sure about this particular machine, but most all-in-one machines have a separate scanner driver and its installed differently than the printer driver. Delete the driver program, install the scanner driver first (most scanners require installation of the program before connecting the printer), then connect the machine, & finally install the print driver. Follow instructions carefully when installing. Hope that helps
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • KHAN
      • Aug 2006
      • 261
      OK thanks for your help, I will check and let you know.
      THANKS.
