Hi There, looking for a HP E58650z Service Manual. got error codes 15.B1.A & 61.A2.2D
Re: HP E58650z Service Manual
https://www.copytechnet.com/forums/s...nual-requests/ -
15.B1.A - Is a paper jam / mis-feed
61.Ax.yz
The pick transmission has failed.
• 61.A2.2D (Payload data: 6100002D)
PAPER LOAD TRAY1 PICK MOTOR- Take the tray out and check the white plastic bearing on the pickup shaft at the rear is seated correctly.
You should get 3mm to 5mm of left-to-right movement from the shaft.
Last edited by Cipher; 07-06-2020, 03:28 PM.- Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
Fully qualified technician for Ricoh - Canon - Sharp - HP - BrotherComment
