As part of a modernization of our layout, the Fax/Printer Forums are being merged into their respective brand channels under the main Copier Technical Discussion area.
If your favorite Fax/Printer channel isn't here, you should check there.
I replace the fuser drive assembly for error 59.OF and get the error 5120, this is not error 51.20 it is 5120, any idea?
Copier get to ready and at that moment it jump to 5120 error.
1. Windows Server 2008 R2 Support.
2. Windows 8 Support.
3. Windows Server 2012 Support.
4. Increase fax cover page characters from 500 to 700.
5. Support for HP Future smart devices.
6. Fix for the issue while sending fax job from 32 bit application on 64 bit OS.
7. Improved configuration specific error messages.
