Hi all,
Has anyone experienced the document feeder grinding and not pulling in paper through the document feeder on a HP Laserjet Enterprise M800 series?
The DF rollers have plenty of tread and the only way I can get it to work is to remove the separation pad however there is still a grind noise.
The coupling that the paper pickup assembly couples with looks split however it looks like its meant to be like that as its a clean cut... Normally i would just order the coupling however according to the parts manual, you can only buy the whole document feeder!
