HP 4250/Changing Print Quality
  • cucuklotz
    • Mar 2007
    • 611
    HI.
    I went to machine on Fri,customer complaining about copies being to light. The density looks pretty solid and black,I think the image on letters could be bolder. What can I do to adjust image boldness?
    Thanks, Andy
  • Chewy
    I am assuming that you have tried another toner cartridge, or you are convinced the one in the machine is OK?
    Go to the print quality menu and adjust print density.
    • cucuklotz
      • Mar 2007
      • 611
      HP 4250/Quality
      HI,
      YES +YES
      I tried different cartridge and Set print density to optimize.The quality is not awful,but customer had bolder,thicker lettering in past.
      Anything I could do?
      Thanks, ANDY
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        I would try another cartridge to see. If that is not the problem, check the transfer roller. How many prints are on it? Transfer ever been changed? Also, The print head lens can collect a thin layer of dust over the years.
        • cucuklotz
          • Mar 2007
          • 611
          Hp 4250/Quality
          Hi
          Thanks for reply,Ill try your suggestions on Monday. Im not that familiar with machine,Is it easy to clean and access Print Head Lens?
          THANKS ANDY
          • Chewy
            Gidday,
            pop the RHS rear access cover off, remove 4 screws from top cover (2 at rear inside rear door, 2 at to front under toner access cover / top door). Disconnect the white cartridge drive actuator lever near the RHS hinge of the top door. Lift the top cover off and unplug the cable to the control panel. There is the laser scanner right underneath.
            • prntrfxr
              • 1622
              most of the time it is dirty laser scanner. you're on the right track if you clean that. dont use chemicals. use compressed air or swab it. Additionally, make sure the printer is not in "economode"
              Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
              • cucuklotz
                • Mar 2007
                • 611
                Hp 4250/Quality
                Hi,
                Thank you Chewy for reply, and THANKS MAINE GIRL for always responding to my pleas. Ill follow suggestions when I go back today,or tommorrow.
                ANDY
