HP COLOR LASERJET PRO M281 error code
Re: HP COLOR LASERJET PRO M281 error code
Yeah, its a thing now. The latest update blocks any 3rd party supply.
You should be able to downgrade your printers firmware
Be sure to disable any network interfaces on the printer, use USB cable to downgrade
Removing 3rd party toners before updating helps. You can leave the printer empty
First in the printer :
1. Settings -> Service -> Laserjet Update -> Manage Updates -> Allow Downgrade -> YES
2. Settings -> Service -> Laserjet Update -> Manage Updates -> Check Automatically -> OFF
On the PC:
3. downlolad 20200612 update Dropbox - HP_LaserJet_Pro_M280_M281_Printer_series_20200612. exe - Simplify your life
4. Open the update, choose your printer and update the printer
5. Check after updating if the settings in point 1. and 2. are left as you set them.
This issue applies now on theese printers:
HP Color Laserjet M254nw
HP Color Laserjet M254dw
HP Color Laserjet M280nw
HP Color Laserjet M281dn
HP Color Laserjet M154A
HP Color Laserjet M154nw
HP Color Laserjet M180
HP Color Laserjet M181
HP Color Laserjet M191FW
Here are the links for the working firmwares:
Dropbox - HP_Color_LaserJet_Pro_M254_dw_Printer_series_20200 612.exe - Simplify your life
Dropbox - HP_LaserJet_M153_M154_Printer_series_20200612.exe - Simplify your life
Dropbox - HP_Laserjet_Pro_M180_M181_series_20200612.exe - Simplify your life
Screenshot from the latest firmware update on hp.com, see the discription
Screenshot 2020-11-20 18.31.37.jpgComment
On the PC:
[ATTACH=CONFIG]47372[/ATTACH]Comment
a quick internet search found this: HP Color Laserjet M254nw firmware HP Color LaserJet Pro M254nw Software and Driver Downloads | HP(R) Customer SupportComment
well someone may have a older version.Comment
I found the firmware for the M254nw. The rfu file is in the description of this video: HP COLOR M181 / M281 Проблема с материалами. Прошивка. Firmware Downgrade - YouTube
And the exe file is on this site: Black compa Hp Color pro M280,M281,M254-3.2K 203X
but I was unable to remove the installed unauthorized supplies message. The fatal error message 65 is no longer occurring, but I have still not been able to recognize the unofficial toners, although I tried in several ways. I still had the old HP toners and when I put them in, everything was fine, but as soon as I put the other toners in, the message appears. I think I'll have to buy the originals...Comment
On the PC:
Merry ChristmasComment
