HP Pagewide Managed P77760Z - Error Code 62.01.13
  • Renlie
    • Jan 2021
    • 9
    [Error Code] HP Pagewide Managed P77760Z - Error Code 62.01.13
    Hi all
    I purchased an used P77760Z, when i initialized the printer, print service needed to be activated. A message is displayed, it will take 22 min aprox. But after a few minutes, it shows the code 62.01.13 - Printhead error.
    Does anyone know anything else about this code? Dead printhead? I don't know what to do, I've thought about updating firmware.
    Thank you in advance.
    Edit. Now it reached 64% print service start up and showed code 62.03.13 instead of 62.01.13.
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: HP Pagewide Managed P77760Z - Error Code 62.01.13
    Those are print head temperature errors. Was the machine shipped with all of the packing holding the print head in place and blanks in place of the ink cartridges?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • Renlie
      • Jan 2021
      • 9
      Thank you for your message.
      No, the machine was shipped from Portugal to Spain palletized, with empty used cartridges inside it.
      I've upgraded firmware to the latest available, with no success, the error keeps changing everytime, from 62.01.13 to 62.09.13
      62.XX.13 (XX changing from 01 to 09 until i gave up trying).
        since day 1 on this line of inkjets the printhead was known for excessive failures... the PH is hard as shit to replace and often times fail shortly after replacement.
        I wouldn't give my dog one to use.
        from an hp forum: Thank you for your query to HP forum. I will try my best to help you.
        This is very likely a print head defect and it is not fixable so you would need to have it replaced. Please call the service center in your country to have your printer replaced if it is till under warranty.
        biggest POS's HP EVER MADE!
        • Renlie
          • Jan 2021
          • 9
          So I guess I do have very little options with these errors
          • Venom
            • Nov 2009
            • 765
            In training we were told these will give print head issues if packing isn't used. Never move across a parking lot without print head packing....let alone ship it.
            • Tonersniffer
              • Nov 2012
              • 74
              Old Post but, been there done that. Take the quickly removed exit tray then top cover off exit side of the paper. Turn the power on and if the service sled (sled with cleaning felt belt) doesn't move horizontally tell the customer "you are screwed." A small belt breaks that drives that sled and stops the print head from lowering/raising. HP doesn't sell this belt. I called my HP service Regional manager and he couldn't find it either. 156mm belt with 1 mm pitch and 156 teeth 3mm wide. The one in my shop needs one.
              • Crowfeather
                Printer firmware is !&$!
                • Mar 2021
                • 130
                Hi all
                • Renlie
                  • Jan 2021
                  • 9
                  Hello all.
                  I will update. Printhead was replaced by HP service, and it was amazingly cheap: less than 600USD.
                  The new printhead passed 300.000 prints now and still working like a charm.
                  Thank you all for your help, this is a nice forum.
                  • KeshaTotenkopf
                    • Nov 2021
                    • 15
                    And nobody tried to repair the printhead. In the same place, some element probably burns out that can simply be replaced, and not completely change the head.
                    • Renlie
                      • Jan 2021
                      • 9
                      Unfortunately, HP does not care about it. They just sent new printhead to local technicians and they replaced it. First time for them to do so. A3 pagewide printers are not very common here.
