HP Ent 700 M775 Tray 3 overfilled (Empty on control panel)
  • Doug James
    • Jan 2012
    • 935
    [Error Code] HP Ent 700 M775 Tray 3 overfilled (Empty on control panel)
    Hello, Been out there twice now. Nothing stuck in paper feeder assembly. The paper tray doesn't come up at all at anytime. I changed the tray 3 circuit board. I swapped the size sensors and gear assy with tray 4 no change. Tried different trays, also swapped the motor, no change. From some of the previous post it looks like the formatter board next. Pic of control panel... Any help very appreciated
  • Doug James
    • Jan 2012
    • 935
    Re: HP Ent 700 M775 Tray 3 overfilled (Empty on control panel)
    Turns out that the paper feeder assy was bad. This after changing formatter and everything else... ugh. Hope this helps someone in the future...
