HP Laserjet Pro MFP M130a faint print
  • Printer77
    • Sep 2019
    • 58
    [Misc] HP Laserjet Pro MFP M130a faint print
    Hi, i have HP Laserjet Pro MFP M130a and the problem is that sometimes left side of print or copy is pale. New drum and toner was put in, all contacts were checked, inside of printer was cleaned and whole printer is checked for missing parts.. Everything looks ok... It works for a few days and then it fades again..
    The picture is attached.TapScanner 02-18-2021-10.18.pdf
  • ninja_unmatched
    • Aug 2019
    • 14
    Re: HP Laserjet Pro MFP M130a faint print
    Check the transfer roller. Make sure it is even the best you can.... look at the springs see if they are worn.
    If one side isn't pushing with right tension, it can cause that... replace
    Sent from my SM-N960U1 using Tapatalk
