HP M177 color MFP
  • Zesti
    • Jun 2009
    • 315
    HP M177 color MFP
    Hi,
    Have this HP M177FW mfp with a dead display. No indicator lights and no display. The power ON button does works and printer turns on and even prints. Initially checked panel but nothing was obvious then checked the Formatter board and found an IC U11 burned and part no is unreadable. Its seems to me some DC voltage regulator. Any one can share the exact part number of U11 component?
    A board snap is attached for reference.
    Re: HP M177 color MFP
    Originally posted by Zesti
    Hi,
    HP does not condone techs doing board level repairs...just swap the whole board.
    • Zesti
      • Jun 2009
      • 315
      Already doing this, just curious!!!!
      Found part No. RIJOH or R1J0H now searching for this SMD code..... Basically I'm an electronics engineer so that's why a bit curious.
      Anyways thanks...
      • Drivee
        • Nov 2020
        • 322
        You can read..
        Bay electronic microscope. 20-30usd..
