Hi all.
I don't have any real experience with this model, but I've worked on quite a few different HP's over the years.
I was called out to service an M605 printer recently that I was told was jamming.
The rollers were obviously worn, so I installed a new set, printed several sheets and left.
A few days later I'm called out again, and further explained that it only did it on the first job in the morning and then would run fine for the rest of the day. They had left the paper inside so I could see it when I arrived.
It had stopped just before the fuser with no rotation.
I figured that maybe the sleeve could possibly be a little 'gummed' up which might cause it to not rotate properly on the first job, and I've seen this before on a couple of copier models that I worked on.
I fitted a fusing unit from a brand new Maintenance kit that they had on site.
They called the next morning - same issue.
There was a message of "unexpected paper size" (at some point) that I noticed on the screen, and the jam code is 13.B2.A2 which I believe indicates just that.
This jam that they left more me to see had not travelled quite as far - maybe 2 inches past the transfer roller
The paper was being fed from tray 3 so I removed the paper and asked them to use tray 2 to see if the problem persists. It did.
Might it have something to do with recovering from sleep mode .
I have the printer back at my shop to see if I can duplicate the issue.
The firmware is from 2015, and I'm considering updating it, but I'm interested to see if I can duplicate the issue prior to really doing anything else.
Anyone experienced something similar?
I've not checked the driver configuration and am also wondering if it could be a paper size setting conflict there.
I do know that the machine is set for A4/ Letter size override (if that means anything).
I've messed around with paper size settings on the print driver I installed at my shop, and it doesn't seem to affect anything.
Thanks!
Thanks!
