HP MFP E77822 copies out black page.
  • nelo
    • Apr 2019
    • 32
    Hi Everyone, I have this HP model that copies out black page when an original is fed through the dual document feeder to do a one sided copy.
    If I do a copy on the platen glass the copy out is fine.
    If I do double side copy, only the 2nd side prints ok but the 1st side is black.
    Printing from PC is all good.
    I checked the lamps home positioning and is ok.
    I further observed that, when I feed an original through the dual scan document feeder the scanner lamp comes on so quickly then goes off then the paper passes the scan glass while the scanner lamp is off.
    Since copying from the platen glass is fine which tells me the scanner lamp is ok, I am suspecting a timing issue between the scanner lamp and the paper feeding through the dual scan Doc Feeder. Most likely a firmware issue.
    And since the admin and service accounts are password protected I couldn't print error / event logs to check on any error codes. I have to collect passwords tomorrow morning from the user.
    If anyone who have came across similar issue confirm if the cause of this issue is firmware related.
    Regards
  • Zeldaman
    • Mar 2011
    • 946
    • nelo
      • Apr 2019
      • 32
      Re: HP MFP E77822 copies out black page.
      Thank you for your reply. I Was able to fix this issue today. I downloaded the updated firmware and uploaded into the machine. I did a test copy and it came out just right.
      Thanks!
      • Pointbreak
        • Apr 2019
        • 2
        I having same issue as you.. I need trying to upgrade firmware and test
