Anyone know if I can take the little wireless board that plugs into the main board off a FDW version and install it on a FDN model and it accept and work? I have a parts machine and I suppose I could take the entire main board with wireless attachment and swap it over, but it has a lot of copies on it and the one I want wireless is new so I'd like to keep that meter for the customer to know what they're buying. I'm wondering if they are different main boards between the FDN & FDW, or if installing the wireless board will cause the FDN to act like a FDW and boot up the wireless menu on the screen.
HP M426 wireless compatability
HI the part numbers on the boards are the same but you cannot use the wifi card in a fdn - as the main bios flash is programmed to the board to be only fdn. I have attempted to flash the firmware/ as i have the main bios flash for m252 and m277n dw ones. but i'm still working on it but at the moment its not possable.
