Hello guys, i hope your doing good.
jams either constantly, then works after i poke around or for a few days.
this was jamming all the time, until i removed the fuser. it had some wrinkling on the film, so i replaced with a reman. worked a few days, and back to square one.
i isolated the paper drawers, and that only helped for a short time. sometimes when it jams and stops, there's a paper trying to get out the exit roller and kind of wrapped around in there.
i cleaned all the finisher rollers i could get to, blew out all the sensors i could see, and it worked fine for a few days.
the machine has 2.3 million on it.
does it sound like the finisher exit mod, i forget what its called, the jogger stacker?
the parts book on this one calls it a swing guide assembly, or a operation tray assembly, or a return roller assembly.
there's also a stack delivery roller drive clutch.
the predecessor finisher on the HP 9050 MFP had about 3 replaceable modules for it, that was easy to fix issues.
if the finisher is anything like the ADF, it's just easier to replace the assembly. if one is still available?
any help, or ideas would be greatly appreciated.
thank you, Jim
thank you, Jim
