HP E87650 81.09.00
  • DSharpe
    • Apr 2018
    • 36
    HP E87650 81.09.00
    Morning Guys, Ive got an HP E87650 thats coding out with 81.09.00. It does it seconds after you plug in the network cable. Firmware has been updated. Thanks
  • ZoZo
    • Jan 2020
    • 30
    Ready state with no ethernet cable plugged in? Sounds like a bad print job.
    • DSharpe
      • Apr 2018
      • 36
      Well, due to it freezing i had the ip changed so nothing had been printed to it. Still coded.
      • ZoZo
        • Jan 2020
        • 30
        Error 81.09.00
        Root Cause: Internal Jetdirect Inside Networking event.
        Recommended Action:
        1. The technician will need to re-establish the trusted platform module state in the printer.
        2. Confirm the error still boots to the same 81.09.00 error.
        3. Turn the printer off.
        4. While turning the printer on, go into the preboot menu.
        5. Select admin > Scroll to TPM > get status> enabled.
        6. Select Disable TPM > confirm > Device reboots.
        7. Once the unit is booted to ready, print the configuration page to validate the TPM is disabled.
        8. Turn the printer off.
        9. While turning the printer on, go into the preboot menu.
        10. Select admin > Scroll to TPM > get status> Disabled.
        11. Select Enable TPM > confirm > Device reboots.
        12. After the printer boots up to the ready status, print the configuration page to validate the TPM is enabled, and verify the error is resolved. Never replace the TPM on a unit that shipped with one. The TPM that can be ordered is only available for adding a level of security on the device never had a TPM paired from the factory, a new one cannot be installed for security reasons.
        • DSharpe
          • Apr 2018
          • 36
          This one doesnt have the TPM.....after several attempts I finally removed the back and there wasn't one installed. Thanks for digging around for answers, i appreciate it.
          • ZoZo
            • Jan 2020
            • 30
            No problem, I'd replace the formatter.
            • DSharpe
              • Apr 2018
              • 36
              ZoZo, we only have one of these in the field and mostly service Ricoh and Konica Minolta so im not familiar at all on them..............IS the formatter board the same as the main board? I ordered the main board a few days ago. Thanks
              • ZoZo
                • Jan 2020
                • 30
                I've never heard them referred to as the main board, in all documentation it's always the formatter pca. Semantics aside, as long as you ordered the board with the ethernet port you should be good.
