I have a 13.20.00 error code that comes up immediately on an HPCLJ CP6015x when it finishes
initializing. I've tried cleaning all the sensors on and around the
fuser with no luck. Can not clear the error and no paper to be found.
Can't even run a sensor test in diagnostics just bombs me out of it
if I try to run it and goes right back into the 13.20.00 error and
thinks there's a jam in the right-side door and nothing to be found.
Any suggestions to clear it?
