trying something on a 8150 laserjet
  • ComputerMonkey
    • Sep 2008
    • 69
    ok we need to print invoices directly from open office to the 8150
    right now when doing invoices we keep paper stacked in the 3 colors
    i want to know if we can simply set something up to print page 1 to tray 4 (white) then page 1 to tray 3 (yellow) and once again to tray 2 for the pink copy
  • jtymabel
    • Aug 2008
    • 164
    try this on the pcl 5e driver...first page from one tray and the rest from another....and maybe a back cover from the other tray.
    • ComputerMonkey
      • Sep 2008
      • 69
      unfortunately since its 3 copies of the same job all 3 print from drawer 1 then 3 blanks from the pink tray
      • jtymabel
        • Aug 2008
        • 164
        you are right....what application are you using to print the invoices...maybe there is a way to create some kind of script to print. (or shortcut)
        • prntrfxr
          • 1627
          I'm not sure how, cause I've never had to do it myself. It has to be done with either the driver or Jetadmin programs, so I always let IT department do it. We use ProSeries for our accounting/inventory in-house. They have the warehouse printer set up to print Packing List (white), Picking Ticket (white), and Core return form (blue) for each order. I would think it would have to be generated as 3 separate jobs, but it all happens automatically when the salespeople enter the order. Next time I see my IT guy, I'll ask him.
          Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
          • ComputerMonkey
            • Sep 2008
            • 69
            im using open office (built the invoice template all by myself and im realllllllly proud of it)
            if you can get your it guy to give me the details i will be eternaly grateful
            • ZOOTECH
              Senior member of CRS
              • 3375
              I'm not familiar with HP's drivers, but it is called 'carbon copy' with the Sharp printers. With Sharp's drivers you can select a different drawer for pick-up of the same printed page. Try this link and look at the second page with the driver image to see if this option would help.
              • ComputerMonkey
                • Sep 2008
                • 69
                yeah the driver setup thing see the print 3 copies as all being page 1 so i guess im looking for a caron copy feature or a program to multi send to 3 drivers and have the drivers tray locked
