HP Laserjet Pro M404 Lever stuck
  • jaydean
    • May 2025
    • 13
    HP-lever.jpg Hi Folks
    I have a customer in Cairns who has 4 HP Laserjet Pro M404DN printers and we supply non genuine CF276X toners for them. For some reason the last batch we sent to them 2 of the printers accept the non genuine toners perfectly, the other 2 of the exact same printers have a small white lever on the RHS which seems to be jammed. No mater what the customer tries 2 of the machines will not allow him to fit the non genuine toner as this lever is stuck on both. It's weird as 2 fit fine, the other 2 won't. Does anyone first of all know what the lever does and secondly why on 2 of the machines they are stuck rigid? I have attached an image of the lever.
  • ATM
    • Apr 2025
    • 37
    This mechanism is stupid like that. Same thing happens in M402 / M426. All You need to do: wiggle it with a little more force and it will work again. It's what we do.
    EDIT: What it does: it makes sure that drive shaft in toner is positioned correctly and doesn't slip out.
    • jaydean
      • May 2025
      • 13
      Hi ATM
      Thank you so much my friend, that is fantastic. I really appreciate your help with this, you're the best. I will pass this on to my customer. Have a great day.
      Kind regards Dean
