HP CP4525 giving "GE Issued Warning 76" error
  • Rich123
    • Jul 2015
    • 35
    HP CP4525 occasionally prints a page that reads "GE issued Warning 76". The rest of the page is blank. I was using the USB port when this happened. I have not been able to replicate the problem using network port. Any ideas? Bad formatter board? Thanks.
    • 37357
    Re: HP CP4525 giving "GE Issued Warning 76" error
    What have you tried so far, if anything?
      I did a quick google search and here's what I found
      HP LaserJet P3015 - My Solution to GE Issued Warning: 76 was to configure the Port Settings to LPR.
      1. Click the Ports tab on the Printer's Properties.
      2. Click the desired port you plan to use.
      3. Click Configure Port...
      4. Select the LPR radio button.
      5. Set Queue Name to any name you want.
      This also has solved an issue with an HP printer spewing copies of a one page print job.
      Thankfully, I found a solution to this problem, it eventually lead to re-adding the printer on to the users PC, but also installing the PCL 5 driver instead of PCL 6. This worked like a charm.
      • Rich123
        • Jul 2015
        • 35
        Have only tried reinstalling driver.
          • 37357
          What driver are you using?
          • Rich123
            • Jul 2015
            • 35
            PLC 5 driver.
