HP m607 and 37x
  • GTgosu
    • Mar 2013
    • 19
    HP m607 and 37x
    I have good m607 and broken m608.
    Who know know how to make m607 it will work with toners 37x. Witch parts i must swap.
    after changing ,formater board and mainboard, the printer detects as m608 but the 37x toner still detects to be incorrect.
  • wav
    • Oct 2021
    • 284
    Re: HP m607 and 37x
    hi if I remember the m607 have a small black plastic piece to only allow small standard toners but if you remove it should allow it to be registered.
    I have swapped a formatter board and the dc board into another machine to get in to a m607 to a m608.
    hope this may help.
    • wav
      • Oct 2021
      • 284
      Re: HP m607 and 37x
      btw when you say incorrect.
      does it give you a supply memory error if so its the small chip on the toner isn't being read or the small brass contact pin in the machine are not lowering down to make a contact.
