HP M608 error 81.09.00
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    This machine was throwing this code while not being plugged into the network. After talking with some tech support I replaced the formatter. Still boots up to this code. I used the emc board from the old one. Could this be stuck in the EMC board? If not that, what else would cause a nic related code? Also. I haven't been able to get it to take firmware, I assume because of the code. Using the same stick and package I had just loaded into another machine.
