HP E62665 not receiving faxes
  • MHeon71
    • Oct 2008
    • 489
    I just installed the 700 series fax kit and there seems to be limited fax settings to play with.
    I do get the handshake and then it drops off. I probably have a 5 to 10% success rate on receiving faxes.
    I unplug the fax line and call the fax number and it will just continue to ring, nothing picks up. I do not seem to have a problem with sending faxes as they all say successful. I have slowed down the transmission rate.
    They are on Comcast lines and the previous Sharp worked fine. I have loaded the latest and greatest firmware bundle of 5.06.
    Any help would be appreciated.
    Re: HP E62665 not receiving faxes
    what TYPE of line do they have a true analog or digital?
    slowing down the baud rate might not be enough look in service manual for other settings.
    • MHeon71
      • Oct 2008
      • 489
      Comcast is a digital line. The machine and fax manual does not offer much help. I looked for ECM while I was there, but I did not think I saw it. I have to go back and check again.
