HP M283fdw contrast problem
  • Profibastler
    • Nov 2014
    • 101
    Hello Folks,
    the HP Laserjet Pro M283fdw with contrast problems.
    Original Toner built in, calibration ok.
    Laser scanner (all mirrors) has cleaned, little bit better.
    What should i do again.
    See attached demo print.
    THX
  • wav
    • Oct 2021
    • 285
    Re: HP M283fdw contrast problem
    Hi you can go into secondary service menu and manually adjust each colour
    Sent from my SM-G998B using Tapatalk
    • ginolab19
      • Sep 2023
      • 5
      Originally posted by Profibastler
      Hello Folks,
      THX
      you have to clean the mirror in image scanner and also the disk inside the image scanner. use cotton buds for cleaning
      • Profibastler
        • Nov 2014
        • 101
        That`s right, did it, see my text.
        • Crowfeather
          Printer firmware is !&$!
          • Mar 2021
          • 130
          Perform manual calibration.
          If problem persists do a jam test.
          If jam test shows complete image on drums, then check transfer mechanism is sufficiently pressurized.
          If jam test shows incomplete image on drums, then check drum unit, and charge supply. Also check output for CTD report.
