HP E87640 Color Laser jet Error code 63.00.2a
  • Edward
    • May 2019
    • 32
    I just got a call for army corp of engineers to resolve error code 63.00.2a. The service manual is vague with this code. Just says printer
    engine connector problem. I feel that it is a yellow image unit corona shorting out. Can anyone give me some support I ran out of time today
    and I'm returning tomorrow. I thought at first fuser but everything looks fine and I can feel a little heat on the rollers when it codes out so I feel it's not that. Thank you in advance
  • Murv
    Sr. Escalations Analyst
    • Mar 2021
    • 182
    Re: HP E87640 Color Laser jet Error code 63.00.2a
    HP Service Manuals are always vague on error codes - they are all detailed in each model/series specific CPMD document. See below
    63.00.2A: The magenta H Sync signal of the laser/scanner is abnormal
    Turn the printer off, and then on. Check for the laser/scanner unit motor operation sound during warm-up.
    If the laser/scanner unit motor does not make a sound, skip to the next step.
    If the laser/scanner unit motor makes a sound, complete these troubleshooting steps: (if no sound, skip to next bolded step)If the laser/scanner unit motor does not make a sound during warm-up, complete these troubleshooting steps:
    Turn the printer off, and remove the power cord.
    Remove the back and the left side covers.
    Disconnect and reconnect the laser/scanner FFC on the laser/scanner and the connector 23 on the main board PCA.
    If the laser/scanner unit flat cable is defective, replace the FFC.
    Part number: JC39-02253A, LSU FFC
    If the error persists after replacing LSU and FFC, replace the main board PCA.
    Part number:
    E876x0z, dn: JC82-00543A
    E876x0du: 5CM63-67001
    • Edward
      • May 2019
      • 32
      Part number:
      Thank you very much
