HP 4100 reset
  • frank
    HP 4100 reset
    how do I reset a maint light on a hp4100, it not the same as a 4000?
  • raym
    • Apr 2005
    • 62
    Re:HP 4100 reset
    press and hold down left side of the \"item\" and \"value+\" buttons while turning printer on. release buttons when \"reset maint. count\" appears in display.
    to verify it has been reset, press \"menu\" until \"information menu\" appears. press \"item\" until \"print configuration\" appears, then press \"select\" to print \"config. page\".
    good luck,
    ray
    • 10871087
      • Jan 2005
      • 1062
      Re:HP 4100 reset
      there is a list of all the hp pm light reset procedures posted in the download section on this site, gotta keep that one in the truck B)
      • Sally
        Re:HP 4100 reset
        I have followed instructions as I understand them but can not get this to work.
        Perhaps misunderstanding what buttons are \"item\" and \"value\" placement.
        This is HP4100mfp series. Tried top, bottom, left and right to the select
        • pensivetm
          just remove the misformed html tags to read the text:
          press and hold down left side of the item and value buttons while turning printer on. Release buttons when reset maint. count appears in display.
          to verify it has been reset, press menu until information menu appears. press item until print configuration appears, then press select to print config. page.
          • pensivetm
            Where
            How do you get to the downloads section? Is that a pay function?
            • JustManuals
              • Jan 2006
              • 9838
              downloads section?
