lj 5035
  • bonnie750
    • 302
    lj 5035
    Just installed a new 5035 with fax option. when i print a config page all the fax info is present, setting up the fax was no problem, but there is no fax 'button' on the ops panel. This is a new one on me.
    Any ideas out there?
  • prntrfxr
    • 1626
    lj 5035
    Some of them I think do not have fax function, but only PRINT/COPY/SCAN.
    HP has a link that explains fax function:
    HP LaserJet M5035/5025 MFP simulations - fax - HP Small and Medium Business
    Hope this helps you.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • bonnie750
      • 302
      thanks for that..I've been there and had a look but that's not the problem. when a config page is printed all the fax details are there but the button on the ops panel is not being generated for some reason. A colleague is going back to the customer and he''ll let me know if he finds the answer.
      • Berny
        HP toolbox
        • 33
        1/ if you dont configure the FAX in the administration menu, the fax icon dont appear
        Administration / initial setup / Fax setup / ( location and fax header information )
        2/ Fax icon may be disabled in the Embedded web server type IP adress in Internet explorer and look in the setting tab / control panel
        3 / try a NVram init
