Laserjet 4100TN - Noisy.
  • bnmand
    • Sep 2008
    • 383
    Toner has just been changed and now the printer is unusually noisy on startup and when printing. Any ideas as to what's gone wrong?
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Can you turn it up, I can not hear it from here. What kind of noise? Squeak , click, clack, grind?
    • bnmand
      • Sep 2008
      • 383
      I'm not very good at describing noises. A friend said the noise is like a squeak or a whistle. It's only there when turning the printer on and printing.
      • prntrfxr
        • 1622
        When you put the other cartridge back in, does the problem go away? You may have a defective cartridge.
        Noises are the most difficult to troubleshoot, but squeaks and whistles are usually cartridge related, while thumps are p/u areas and fuser areas and grinding comes from gears and fuser areas. Try a known good cartridge from another machine not making the noise.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • kuby
          • Oct 2007
          • 1409
          If the noise started when you put in the 'New' toner cartridge, I would say it is the toner cartridge.
          • bnmand
            • Sep 2008
            • 383
            Ok. So is it bad for the machine to use the cartridge (if it is the problem) or can I get away with continuing to use the cartridge?
            • prntrfxr
              • 1622
              Squeaking is coming from the PC drum in the cartridge, which means something is scraping it. Eventually you will probably have image problems, if you dont already. If its a new cartridge its defective (can even happen on an OEM cartridge). You should have a warranty. Return it and get a good one.
