Color Laser Hp 4650, Dead Display
  • KHAN
    • Aug 2006
    • 261
    hi,
    Ihave Hp 4650 Color Printer ,the Display Is Completly Dead,no Led Glows And The Lcd Is Also , But When I Turn On The Printer It Takes Its Warmup ,but Display Is Totaly Dead, I Want To Know Before Checking The Power Supplty Pcb ,is There Any Thing Or Some Codes To Turn On The Display?
  • Wild Bill
    • Jul 2005
    • 774
    Originally posted by KHAN
    hi,
    Hello, Here is what is in the service manual RE: Trouble shooting.
    Troubleshooting power-on
    When you turn on the printer, if it does not make any sound or if the control-panel display is blank,
    check the following items:
    1 Verify that the printer is plugged into an active electrical outlet that is of the correct voltage.
    2 Verify that the on/off switch is in the ON position.
    3 Make sure that the rear fan is running, which indicates that the system is operational.
    4 Verify that the firmware DIMM (HP Color LaserJet 4600 models) or CompactFlash (HP Color
    LaserJet 4610n and 4650 models) and the formatter are seated and operating correctly.
    5 Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again.
    6 Make sure that the control-panel display is connected.
    7 Check the fuses in the power supply.
    8 If necessary, replace the power supply.
    9 If necessary, replace the DC controller.
    262 Chapter 7 Troubleshooting ENWW
    I have seen the panel go blank when I forgot to put back a dimm. Try reseating all and the reseat formatter also. Good luck!
    Izzy
    • KHAN
      • Aug 2006
      • 261
      HP 4650 color
      thanks For Reply,
      ok I Will Check These Points , The Machine Truns And The Fan Also Work The Heater Unit Also Heats,
      • KHAN
        • Aug 2006
        • 261
        HP 4650 color dead DISPLAY
        i Visit The Customer Office Today , I Checked All The Points That You Mentioned ,all The Fans And The Heater Unit Works When I Trun On The Printer,
        but What They Do , They Says It Was Ok But They Refill The Colors Cartridges And The Printer Work Just For Few Hours And Then Happens That . I Am Going To Check The Power Supply Unit ?
