HP designjet T 1100 ERROR 21:13
  • KHAN
    • Aug 2006
    • 261
    HI,
    My HP Designjet shows ERROR 21:13 and restart printer, Each time i restart the same code comes and nothings to move,Please I need help what is it for or someone have SERVICE MANUAL for T 1100, I will be grate full.
    THANKS.
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
    from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • suckis
      • Dec 2006
      • 165
      System Error: 21:YZ (YZ = 13 ==> Power OFF)
      Problem Description: Fail moving Service Station.
      Corrective Action: Try the following:
      • Switch the Power OFF from the back of the Printer and disconnect thePower cord. Check the Primer Tubes. Reconnect the power cord andpower On the Printer.
      • Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station.
      • Perform the Service Station diagnostic test to troubleshoot the problem further ⇒ Page 4-42.
      • If the System Error continues, replace the Service Station ⇒ Page 8-55.
      • If the System Error continues, replace the PrintMech PCA ⇒ Page 8-66.
      KHAN, give me your mail so I can send you the manual.
      ! RTFM !
      My site: http://www.e-club.gr/
      • KHAN
        • Aug 2006
        • 261
        THANKS sir,
        I have manual for this,
        I run SERVICE STATION AND DIS but same ERROR.
        • jeff33
          • Aug 2009
          • 61
          When the T1100 first came out there was a problem with PHs and the SS failing because they were spitting too much ink into the SS. They fixed this with a firmware up grade. If you replace the SS I would also upgrade the Firmware.
