HP bussines ink jet 2800
  • vaclav borc
    • Jan 2008
    • 75
    the printer is not workink ok. It halts or restarts accidentaly. It seems like wrong firmware. Where can i
    download firmware?
  • CanonHPTech
    • Apr 2007
    • 235
    Version PMR2006A
    ftp://sbdj:fwdownld@hprc.external.hp.com/bij2800/pmr2006a.exe
    Good luck. These weren't as bad as the HP CP 1700's, but the support/help is about the same= non-existent. My only suggestion would be to make sure you have all good HP cartridges, clean encoder strip (I think this one has one?), and do any resets/clears on machine per the service manual. If that doesn't help, put it on eBay as a junker. Business-class or not it is a junker. I've had DeskJet 500's and 900's, which are non-business class, run for over 10 years without hicups. You tell me. Please post your results.
    The glass maybe half full, but less is more...
    Printer + Fax + Copier = Jack Of Many Trades,
    but Master Of None
    Color Copier = Not A Color Printer
    InkJet MFP = Not A Fax Machine
    B/W Copier = Not A Press
    Finisher = Deal Closer (salesman, not accessory)
    Copier Tech = Admin's Stress Ball (Scapegoat)
