Message:
We have an HP 9050MFP under service that is giving the 49.4C02 error code whenever the customer selects a speed dial # to send a fax. The machine will also throw this error if you try to print out the one touch dial list. The fax works fine as long as you dial your destination number manually.
The service manual refers to the 49.4C02 error as a printer error resulting from a critical firmware error.
This machine is in a fairly remote location so I would appreciate any suggestions on finding a solution to this problem.
Here is a list of troubleshooting I have done:
-Cold Reset
-Updated to latest firmware
-Hard Drive Initialization
-Removed unnecessary options from formatter
I appreciate any feedback
-Clint
-Cold Reset
-Clint
