OK guys....I ran into this same problem years ago and never found a solution (customer did not want to fix the printer). It is with an HP 4000 that feeds paper just fine, however at times it seems to try and feed again after the sheet has already started into the printer. Now this causes no issue during a print job, but after the print job finishes it results in an extra sheet sometimes being fed into the printer that stops about half way thru the fuser. There will be no jam indicated UNTIL the next print job starts. Then it will indicate a paper jam. Does this intermittenly but I have watched it and seen this numerous times today.
This is only when using tray 2. The front fold out tray out "tray1" works fine with no issues at all.
The printer has all new feed rollers and I have done the torque limter "mod" to reduce the separation torque.
Any ideas?
Any ideas?
