My Hp 4200 Laser printer gives me 60.2 error
  • emre09
    My broken Hp 4200 printer gives me 60.2 error
    when I open. It doesn't receive tray.
    If you give me an information about my broken
    piece, I will buy a spare part on
    this website. Thank you. Have a nice day.
  • DavidEtling
    • Feb 2005
    • 31
    HP 4200
    Manual says it's a tray 2 lifting motor! Page 290 of service manual.
    • J_Lee
      • Oct 2008
      • 111
      Try reseating the try 2 lift motor
      • prntrfxr
        • 1627
        60.x Error - HP 4200/4300
        Here's my service note on this one. I've had this problem lots of times:
        SERVICE NOTESymptom:Problem:Resolution:Symptom #1Symptom #2 Symptom #3Symptom #4
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • ExOceMan
          • Sep 2009
          • 63
          Have you tried to power the machine off and start it without tray 2 installed? If that works then it could just be a tray problem those trays are cheap plastic garbage.
          • Deano
            • Oct 2009
            • 21
            ive got the same problem, 60.2 error. 4350. Just taken the side off to check the DC controller, and noticed a spring on the bottom, which i guess has come off the tray 2 lifter motor, anyone got a diagram to where the spring must go? as cant find it in the service manual
            thx in advance
            update, i corrected that problem, i ran a 50 page print, and it locked up, took toner out, and the cogs that turn the toner has snapped now
            • J_Lee
              • Oct 2008
              • 111
              Check out HP Partsurfer you can see the whole tray broken down to the screw! Just make sure you have your model number makes it a lil easier.
              • prntrfxr
                • 1627
                Spring goes from the lift drive to the main drive gear asm. Attaches at the bottom and is so fun to reattach. There are 2 springs on the tray. One that provides tension for the separation roller and a torsion spring on the roller door. Hope this helps you.
                • Realtech
                  • Oct 2009
                  • 103
                  hp lj4200
                  There is a spring on the lift motor check if they are missing?
