hp m1120 freezes
  • tonerspot
    • Nov 2008
    • 79
    hp m1120 freezes
    hp m 1120 shows initializing and freezes over nvram reset did not pass any help
  • prntrfxr
    • 1627
    hp m1120 freezes
    try installing new firmware or reseat firmware chip. Make sure all optional equipment is removed (jet direct card/opt tray etc...) You may have a bad formatter
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • tonerspot
      • Nov 2008
      • 79
      can i instal new firmware without inizialization
      • prntrfxr
        • 1627
        hp m1120 freezes
        If everything I've said up to now sounds like Greek to you, take the machine to a trained professional. Please...
        Ok, guess I have to spell this out...
        If it is under warranty, get HP to replace unit. If not, go to next step.
        If it has a built in network port (network port soldered to the formatter).
        If it has a jet direct card, power down printer, remove the jet direct and power it back up. Does it go to ready? Yes = replace jet direct card. No = go to next step.
        Does it have a firmware DIMM or is firmware built in?
        If it's built in, replace the formatter. (The formatter is the main board that has the USB & Network port/slot for network card.) If it is a DIMM, try reseating it. If it has the same problem, replace the DIMM.
        Try thinking first, it's free and can save you money later.
