As part of a modernization of our layout, the Fax/Printer Forums are being merged into their respective brand channels under the main Copier Technical Discussion area.
If your favorite Fax/Printer channel isn't here, you should check there.
55.1 is a DC Controller error............turn off machine for at least 30 seconds then back on let the machine reinitialize....if code comes back replace the dc controller...........Happy New Year
