Curious if anyone has seen this fault....
Without phone cable attached boots fine consistantly
With phone cable attached (after the initial HP logo) it gets to a pink screen with flashing CF card slot light, ready and !. Here it stalls Again consistantly
Once at ready I can plug in the phone line and get perfect results on a Telstra fax-back test.
On pressing setup I can access Photo Setup/System/Service/Network Configuration. Other options are unavailable.
Cause is presumably fax failing to initialise, but is there a setting that could cause this???
