Your problem is related to the ETB. Print or display the event log to get the entire error code for specific troubleshooting. Then compare what you're seeing to the attachment below for the resolution to your problem.
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
I had the same error the other day...changed the fuser and all was well...sometimes it can be the wrong fuser so check the model type...there is two fusers for the same family but they are different and wont interchange...but if its been working change the fuser
You never realize how cheap a professional is until after you let an amateur do it.... and
if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
