HP Laserjet M3035 mfp
  • Realtech
    • Oct 2009
    • 103
    I make one copy with this machine the copy print came out but the data light keep blinking all the time. Job cancel has been perform no job to cancel. Cold reset has been perform ok. Next I make a print out paper can out the data light keep blinking all the time. The network cable has been disconnected than perform cold reset. Make a copy again same reset. Any Idea?
  • Fearless V K
    • 620
    Corrupt firmware?
    Don't take that toner with me!
    • prntrfxr
      • 1622
      Does it do it when you print an engine test? (engine test bypasses the formatter and allows you to print using only the dc controller).
      • thurmmy
        • Aug 2016
        • 102
        Re: HP Laserjet M3035 mfp
        Was this resolved? I have one of these and is doing kind of the same thing.
