hp 4850 jam error 13.12.00
  • pontiac
    • 420
    Only when duplexing paper stops at the same spot going into the black transport assembly cleaned all the rollers, checked transfer assembly cleaned. Thanks for replys
  • pontiac
    • 420
    Sorry everyone just caught a mistake the printer is a hp 4650
    • prntrfxr
      • 1622
      4650 duplex troubleshooting
      Clearing the model up makes all the difference. Thanks.
      There are only 3 things that are mechanically involved in duplexing in this machine. P/U asm, transfer belt, & fuser. If it was the fuser, it wouldn't do regular print jobs either. It is rarely the transfer belt.
      There is a swing guide at the bottom of the p/u assembly that gets broken (80% of the time this is the problem). When it does, it will print straight all day long, but won't duplex. Usually, you will see 2 pages on the back of the transfer belt, but I've seen other positions. The swing guide is gets attached to the junction guide (sometimes this breaks too) before installing.
      Your choices are:
      1) Replace the entire p/u asm. RG5-7453 - 4650 or RG5-6468 if you have a 4600. (do this if the registration roller is worn)
      2) Replace the swing guide. RB2-8303 and the junction guide, RB2-8306 (Requires removal of the p/u asm)
      3) Take a repair kit that has the most commonly used parts when you go out and save yourself another trip: (PM me for kit part number and where to get it)
      (2) RF5-3739: ROLLER, CASSETTE PICKUP
      (1) RB2-8280 FLAG, CASSETTE, PAPER SENSING
      (1) RB2-8306 GUIDE, JUNCTION (BLACK PLASTIC RIBBED BAR WITH TABS ON EACH END)
      (1) RB2-8303: GUIDE, SWING, PAPER PICKUP (FLAT BLACK RIBBED PLASTIC BAR WITH NO TABS ON END)
      Includes Instructions with Photos
      Hope this helps you
