How to set serial number HP 2015
  • oldtech
    • 83
    I have a bunch of these things and it seems the formater fails a lot. My problem is after replacement I have not figured out how to set the original serial number. I understand it has to be done with pjl commands, but I am not a real IT person and I don't know the steps to do this. I can map ports etc and have the file but the devil in the details is killing me. Any help is welcome.
  • oldtech
    • 83
    After a couple hours of trial and error I got done. Hp is useless, you may as well call the first number in the phone book as I am sure you will get info faster that way.
    • Rob Sandberg
      • Jul 2008
      • 275
      Look up some older posts on this problem.
      There is a fix for the formatter boards, I have fixed 3 printers by baking the formatter card for 8 mins at 350 degres f.
      As for HP your are right. My dogs know more about printers.
      Rob S
      • oldtech
        • 83
        My Boss did not want me to cook that formater, he has since changed his mind as we have had another fail. The no lead or low lead solder is a problem on a bunch of HP stuff including laptops. I will still need to be able to change the serial number because of the fleet management deals.
        • Rob Sandberg
          • Jul 2008
          • 275
          If these are network printers you might be able to do this thru the web interface.
          This is just a thought I have not had to do this before.
          Rob S
          • oldtech
            • 83
            Not on the 2015 or the 2727. I have done it through the interface on other models but HP decided not to add that function for these models.
            Again, let me count the ways I hate HP......
            • Rob Sandberg
              • Jul 2008
              • 275
              I'm up to 2gig ways just this afternoon. Had a M2727 that does not know that it is a M2727. It thinks it is a HP Laserjet P @. At least that is what the config page says.
              Rob S
              • oldtech
                • 83
                That's a new one, most of my 2727 trouble has been the going to "sleep" and never waking until power cycle.
                • Rob Sandberg
                  • Jul 2008
                  • 275
                  Yeh and the Nvram reset would not work. Got to get a formatter.
                  Rob S
