HP Color Laserjet CP3505 memory
  • J_Lee
    • Oct 2008
    • 111
    Hello everyone. I have a customer with this color printer and they print very detailed photos full 8 1/2 x 11 size and they cannot print to this machine because it says not enough memory. Now is it just a matter off selling them a 128 MB and popping it right in the slot on the formatter? Any help would be appreciated because they want the maximum memory this machine can have.
    Thanks,
    J.
  • J_Lee
    • Oct 2008
    • 111
    P.S. I looked in the service manual and it doesn't tell you max memory and also how to enable memory from MAC systems that this particular customer uses. Thank you
    • austonrush
      Sharp & HP Tech
      • 234
      Hey j_lee,
      Are they sending there jobs through a USB connection? Make sure jobs are being sent through the HP Jetdirect Fast Ethernet embedded print server
      Max memory that can be added to this machine is 1 GB DDR2 SDRAM DIMM (HP PN: CC412A)
      • J_Lee
        • Oct 2008
        • 111
        Thanks for replying Brandon. They are sending through a regular network cable. They definitely need more memory I just wasn't sure what the max was and how to enable the memory from a MAC! Can you help me out there Im def. not a macintosh person...
        • austonrush
          Sharp & HP Tech
          • 234
          You shouldn't need to do anything to enable the memory. Just Make sure they are sending from a postscript/Mac driver. Just install the memory and go
          • J_Lee
            • Oct 2008
            • 111
            Thanks so much Brandon I will post results!
            • J_Lee
              • Oct 2008
              • 111
              Popped in the 1GB memory and had them print what wouldnt work before. Went right to it...
              Thanks Brandon!
              • austonrush
                Sharp & HP Tech
                • 234
                Your Welcome
