Hp DesignJet 500
  • zeeaxis
    Manager TSD
    • Nov 2008
    • 28
    Hp DesignJet 500
    hi everyone,
    i 'm havin a problem with the subject plotter/printer as it gives a message "Open Window and check printhead cover is properly closed,,,,,,,,,,,,,press enter to continue."
    i have gone through all the checks for sensors n switches but wasn't able to solve it. anybody having any clue that could help!!!!!!!!!!!
  • jeff33
    • Aug 2009
    • 61
    If it says printhead path you need a new belt, or check for a jam.
    • mo0651
      • 1054
      error messages with the printhead can also be caused by loose or damaged trailing cables. Reseat or replace the flat white cables going to pcarriage unit.
