hp 2600n sensor error
  • rods
    • 23
    [Error Code] hp 2600n sensor error
    HP 2600n removed laser unit to clean, after re-install sensor error message ( no code )Cleaned all sensors and same message comes up.Any suggestions.
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • rods
      • 23
      We have a manual, this error is not mentioned in much detail in the manual.
      • prntrfxr
        • 1622
        which sensor error did you get? That will determine where the problem is located. Check flags/actuators first and make sure sensor is clean. Go through the steps you went through to clean the scanner and make sure all cables are connected. Verify good connection by disconnecting and connecting again.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
