how do I reset the \"Perform Printer Maintenance\" message on my HP-4050
HP4050 Maintenance Message
Chuck Morgan
Re:HP4050 Maintenance Message
i recomend doing the maintance first and if you buy a kit from HP or any other distributer it will have the instructions for reset.Comment
imagertech wrote:
i recomend doing the maintance first and if you buy a kit from HP or any other distributer it will have the instructions for reset.I'm going back to Cali, Cali, Cali...Comment
If you reset the maintenance message without installing a maintenance kit, you wil possibly cause some damage to the printer.
hth
paul@justmanuals.comComment
YOU WILL NOT CAUSE DAMAGE TO THE MACHINE IF YOU DO NOT DO THE MAINTANCE!!!!! You however would be wise to do the maint. then reset it .(Paul stick to Selling crap online)Comment
your right it. i just dont care for incorrect information posted to scare someone. i treat this as a profession and if i dont know the correct answer then i dont give my advise.Comment
hmy: You were a bit harsh, Any damage would likely be to the units that need replacment. But I do agree with your attitude about the job and this site. This site will only work for the real tech\'s if we provide correct information, or our best troubleshooting scenario. Doesn\'t matter if your an INDY, or a dealer or an OEM retailer. From time to time we all have to decide weather to \"run it to failure or replace it for reliability\":evil: :evil: :evil:
P.S. Karma 4 honestyMystic Crystal RevelationsComment
Rapid Refill Ink
Do this and all should be good!!
\"The Short Cut Method\"
1. Turn the printer off.
2. Hold down the Item key (minus side of the button) and Value key (minus side).
3. Turn the printer on.
4. Wait for RESET MAINTENANCE COUNT to be displayed and then release both keys.
NOTE: Some versions of the 4000, 4050, 4100, and 5000 will NOT have their maintenance count reset by following the preceding \"short cut\" method. This is do to the many different formatter board revisions. If the short cut method doesn\'t reset the maintenance count then you will need to go into service mode to manually reset the maintenance count to zero.
Good Luck!Comment
This forum is for technicians.Comment
