HP 4345 mfp - clearing Usage Page count
  • kuby
    • Oct 2007
    • 1326
    I know you can clear or reset the page count for the Device Information page and put in a new serial number. But we need to clear or reset the page count for the Usage page. We had to swap out a formatter with one from a new machine and now the new machine show 588,793 copies instead of 256. Is there any way to do this?
  • ucinn
    • Jun 2009
    • 383
    I believe an NVRAM init will do this? I haven't been working on these long, but I believe that will do it.
    turn on, wait for ram to show. press and hold 9 until all three lights stay on. press 3 1 time then start then press 3 two times unitil it says NVRAM init, then press 6.
    • J_Lee
      • Oct 2008
      • 111
      you have to go into service mode and enter the 8 digit pin code. I would give you the pin but not at my office currently.
      • kuby
        • Oct 2007
        • 1326
        I got the code and have done about everything but the NVRAM clear. Will have to look and see what it will clear if I do this.
        • prntrfxr
          • 1637
          Once you key in the pin code you should be able to go to page count and change the page count.
          Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
          • kuby
            • Oct 2007
            • 1326
            Yea you can change the page count but not the count on the Usage Page.
