H/P LJ 4345 MFP paper reversal problem
  • landspeeder
    • Feb 2010
    • 355
    When I print a config page (3pgs total) the first two make it to the top of the printer area and the third stays under the cartridge....if I do a copy of "1" page only it stays in the top are as well...the paper reversal unit does not turn on to feed the paper out...its not a lower sensor as it happins with one page only ...and I changed the paper rev unit yesterday with a new one...not cheap...and there is no difference...so what controlls and supplys power to the rev unit...DC controller?..and they arent cheap either....any ideas......thanks
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • prntrfxr
    • 1622
    check the even log for the actual error code also as that may give you an idea where the problem is. See attachment for additional info.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • landspeeder
      • Feb 2010
      • 355
      It was a bad DC controller! Changed it and it feeds the paper just fine. I left the reversal unit in as maybe it shorted the controller and at the cost of parts who wants to chance it.
      All
