hp 4650dn error: unable to store job at printer
+ More Options
Posts
  • SOCPWB
    Hi, guys:
    Error: unable to store job at printer
    Reason: insufficient disk space for this job
    solution: delete some files from the disk defore resending this job
    I have this message from "job storage status page" , since I'm trying to printer more pages on same document. what can I do now? should I upgrade or change firmware or add more memory?
    please help!!!! thanks in advance!!
  • JustManuals
    • Jan 2006
    • 9838
    Why not follow the solution the printer gave you. Delete some files.
    • prntrfxr
      • 1622
      actually SOCPWB is likely reading what it says on the display panel, because the service manual says:
      "A job cannot be stored because of a memory, disk, or configuration problem."
      Resolution:
      "Install additional memory in the printer, or install a disk drive into the printer.
      If a disk drive is installed, delete any previously stored print jobs."
      Hope this helps you a bit.
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
      • TommyH
        • Sep 2009
        • 118
        Pretty sure you will need to add more memory or a HDD to the printer. Something you can try if still having problem is go into the print driver and make sure Job storage and mopier mode is disabled. I have seen in a print driver that the HDD is installed according to the drive but there is not one in the machine. And when you try to print a large job its trying to store or que it there b/c the driver says those options are installed.
