Hp Laserjet 2420 Dn
  • rschmitt
    • Feb 2005
    • 34
    Hp Laserjet 2420 Dn
    DISPLAY IS BLANK THOUGH THE BACKLIT IS WORKING. ENGINE TEST WORKS. NOTHING ELSE WILL. ALL THE INDICATOR LIGHTS STAY ON. REPLACED THE FORMATTER AND THE DISPLAY. NOW WHAT?
    THANKS,
    BOB
  • BLITZKREAGG
    You might want to go after the dc controller
    • JustManuals
      • Jan 2006
      • 9838
      You might want to check the cable too. Whenever I replace a display I always replace the cable too.
      HtH
      Paul@justmanuals.com
      • prntrfxr
        • 1622
        Hp Laserjet 2420 Dn
        I dont remember if firmware is built into the formatter on this machine or not, but if it is a separate chip, you might consider replacing the firmware chip. A diffective chip can cause that problem sometimes. Does the board you installed have a compact flash chip?
        This may be your problem as well: If the formatter you installed was a refurb, the dc controller may be confused. When you install a new board the dc controller writes to the formatter. If the formatter already has info on it, it will try to write to the dc controller. All formatters for 24XX series printers have the same part number. Unless HP has a secret PJL file to fix the problem, I'm unaware of any method of returning the printer to former condition.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
