Hp4250 Cartridge Assy/disassembly
  • KHAN
    • Aug 2006
    • 261
    hi, I Need The Refill Instruction And Assy/disassembly,
    how To Refill Hp Cartridge 4250,
    i Open The Cartridge From One Side From There I Refill It, It Works Nice But Still Show
    replace Black Cartridge On The Display, How Can I Reset The Counter For Cartridge ,
    thanks.
  • TonerTech
    • Jan 2007
    • 43
    REMAN
    I normally dont remove the plastic welds on contact side I use flex method after removing the gear end plate, Flexing the contact side and lifting the drum up on an angle and away to release the axle
    • KHAN
      • Aug 2006
      • 261
      Hp4250 Refill
      thanks For The Help, I Do The Same Way To Refill,
      i Know The Scc.com But Can Not Log In, Please How Can I Log In To This Site? If You Can.
      • TonerTech
        • Jan 2007
        • 43
        You can also use summitlaser.com and user/password is: AO , on both lines!
        futuregraphicsllc.com/techguides
        In order to reset new chip is needed, will run without but lose supply status, low toner
        • KHAN
          • Aug 2006
          • 261
          Hp4250 Refill
          thanks For The Information.
          the Graphic Site Is Very Useful.
          what Do You Mean By Lose Supply Low Toner .
          thanks.
          • TonerTech
            • Jan 2007
            • 43
            Without new chip cart will function with the same memory and toner left on chip memory and will not be @ 100% and will still run when you enter continue. Just needs to be aware when you start to get light print
